Tyler Hallock
- Hedgesville, WV
- FSH Sport
So I have two issues...First my alarm is going off inside the console of my 210 FSH Sport. I have a four bank minnkota charging system on and all batteries are fully charged. Boat is out of water and I put fish in my bait tank and turn on airator and 10 min or so later the alarm goes off. The motors are not on or anything, I disconnect the house battery and it turns off. I’m the process of trying to trouble shoot I but a new battery in from my trolling motor and hooked up the negative to the positive and turned the parallel on and pop the positive terminal on my start battery burned up. I immediately turned off everything but now motors and screen will not turn on. I looked everywhere for fuses. The battery fuse is still good. However there are two fuses with blue and white wires and the fuse says 120 and it’s really small. One is in the engine bay and the other is under the center console. Is there a secret stash of fuses on these boats and does the systems that allows you to parellel protect against reverses polarity I would imagine they have somthing to protect your boat from this.
