230twinpump
Hi all, new to the forum. I purchased a 2007 AR230 last year. I was out with my family 2 days ago and starboard engine started to act up, felt like the jet had sucked up something, brought star board engine to idle and ran on port engine back to the boat launch. The star board engine and then the port engine started coughed and sputtered and died. It was then that i noticed the bilge pump outlet was spewing a steady stream of water, as i went to open the engine compartment. I found the compartment filled with water, just bellow the air filters. It took the bilge about 40 mins to drain the engine compartment. Found it strange that the bilge was draining (water level was going down) after the engines shut down? Flagged down a fellow boater who towed us back to the launch. Got home checked the oil and both motors had milk shacks in them, currently trying to flush the engine oil, after removing the spark plugs and spooling the engines to remove the water in the cylinders. Flushed the engines 4 times with fresh oil with a cup of diesel in 5 liter oil containers (x3) and still no joy... thinking of removing the oil sumps and cleaning them, before continuing flushing the oil. The engines do start (after removing water from cyls) minus any strange noises. Could really uses your thoughts on how i should proceed?
