Aloha everybody!
Awesome. Great boat. Welcome to the forums.
Thank you, HangOutdoors! I already found a problem with my boat, probably it's a common issue with new Yamaha jet boats. Drainage tube in the bow anchor compartment doesn't fit correctly and water leaks directly into the hull, especially in the rough seas. drainage.jpg
Search the forums here there are about 4 different very active threads on it. You can either just 5200 around it but leave a hole for it to drain, or replace it with a SS thru hull one, etc.
Thanks, HangOutdoors, for the tip! Looks like the problem was for a long time. I can fix it myself, but I'm waiting for response from the dealer.
Not sure what dealer will do. Believe it or not that is how they are manufactured new.
I just want to be sure that Yamaha keeps their warranty if I begin to do some modifications on my own.
