FSH 210 Sport
- Tranquility Base
- FSH Sport
So if I understand this correctly, you had a new transducer installed and the installers removed the clean out tray to gain access to that area where the transducer wires come through, that would explain the dislodged clean out plug. I’m going to guess that they left the the drain line off of the clean out tray that goes from the clean out tray to the bottom of the swim step above the jet pump where it mounts to the transom. This could easily be forgotten when re installing the clean out tray.
Pull the mechanical access hatch off and reach down under the clean out tray and make sure this 3/4” drain line is attached.
The next thing after that is to seal up the clean out tray while it is installed.
I’m also assuming that there was no such leakage before the new transducer was installed.
