Amp recommendations for JL 10" sub
WiskyDan
Jackson, WI
242 Limited S E-Series
So I decided to add a sub (JL 10", 250 watts RMS, 4 ohm) to my audio upgrade and bought one of these:
I need a dedicated amp and thought that this one would be a good choice:
It appears that I could also get a 2-channel amp as well and bridge it but would appreciate any recommendations.
That mono block is the way to go if you don't need to add anything else. It is a perfect pair for the sub.
You can also go with a Kicker PXA500.1 for a bit cheaper.
