Yes. This will give the cleanest and most accurate sound.
Yes any setting above zero will increase the signal level and increase the chance of driving the amps into clipping. Good speakers do not need EQ to sound good and EQ's introduce distortion which is why I refuse to use them. I use placement and room positioning for my home theater. For boats I keep it clean and simple as the open air of a boat is about the worst environment for creating a sound field.
There is no perfect way to do this - there's ALWAYS the risk of damage when cranking up tunes unless you de-tune the gain so it can't be too loud (this is what Yamaha does with their stock systems so they don't get calls for service because 100% wasn't loud enough). You need to learn to hear when the amps are straining and turn it down. If you have the tunes cranked, you need to listen and make sure the music and source are not over-driving the amps.
However, if you insist on using EQ, set it how you want then turn up the gain using your meter to measure. That will not prevent clipping though.
212s, thanks for explaining this in detail. I have asked several people and all I got was conflicting yes or no answers. The EQ im referencing is built into my head unit (Kicker KMC4). If I set the internal EQ to 0, Should I use the gains on the amp to adjust sound levels between speakers? By that I mean, set gains to desired voltage reading and then turn them "down only" to adjust for sound quality?
If your interested in my set up or have any suggestions Im all EARS...
This is my current plan and equipment
Equipment:
Kicker KMC4 head unit
4 x Kicker 6.5 coaxial 4 ohm 50W RMS, in stock locations
2 x Kicker 8" coaxial 4 ohm 150W RMS, mid ship by captain and copilot seats
1 x Kicker 10" sub tube 2 ohm 400W RMS, under captains seat facing stern to bow
2 x Clarion XR5520 5 channel amps under the helm. This amp is probably underrated. I've seen youtube videos of the previous version Clarion amp dynoing substantially more power. That amp averaged of 20 -30% more power than it was rated. I figure if I stick with most of the labeled ratings to do my math, I won't max out the amps.
Clarion XR5520 specs
- 95 Watts × 4 Channels + 320 Watts x 1 Continues @ 2-Ohms
- 55 Watts × 4 Channels + 200 Watts x 1 Continues @ 4-Ohms
- 180 Watts × 2 Channels Continues @ 4-Ohms Bridged + 200 Watts x 1 Continues @ 4-Ohms
Future equipment - Kicker 6.5 coaxial in cans installed behind bimini. I believe this was your idea from another thread. And maybe another 10" sub if needed.
Plan:
Amp #1
Wire 2 - 4 ohm 6.5 coaxial speakers in parallel to channel #1 drawing 95W @ 2ohms
Wire 2 - 4 ohm 6.5 coaxial speakers in parallel to channel #2 drawing 95W @ 2ohms
Channel #3 & #4 left open for future growth.
Wire 1 - 2 ohm 10" sub to channel #5 drawing 320 watts @ 2 ohms.
Amp#2
Wire 1 - 4 ohm 8" coaxial speaker to channel #1 & #2 brigged drawing 180W @ 4 ohms.
Wire 1 - 4 ohm 8" coaxial speaker to channel #3 & #4 brigged drawing 180W @ 4 ohms. I will probably tune the 8's down to 150W RMS.
Channel #5 open for future growth.
The only channel Im slightly concerned about clipping is the #5 sub channel on amp #1. I've heard the Kicker sub wants lots of power. Im going to use the Oscilloscope to find my maximum parameters on this channel.
