no-proplems
- Limited S
I want to simply add an amp to power my 6 existing Polk Audio speakers. Fusion head unit is in the stern. If I’m mounting the amp behind the helm, is it easier to just run all new speaker wire from the amp to each speaker? I don’t think any of the existing speaker wire runs through thy area right?
Or should I mount the amp near the batteries so I can just use the existing wires from the back of the fusion deck? Is that even a possibility?
I’ve searched the forum quite a bit and haven’t found a clear answer to this.
