Judge
- Cape Coral, FL
- 275SD
There has been lots of discussion about water on top of the clean-out plugs and that its fairly normal. Many people believe that water gets into the inspection port area from the swim platform when stopping, etc. and it fills the clean-out access tube.
I used to subscribe to that theory as well.... until I purchased the 275SD. The inspection access covers and clean-out ports sit pretty high up off the swim-platform. You would need to stop dead from 50mph or have a 3 foot wave come over the back of the boat to get water on top of the clean-out plugs. When I first started using the boat I had water on top of my clean out plugs. I wasn't too worried about it since I had seen this with previous Yamaha boats.
However, I had at one time theorized that water getting on top of the clean-out plugs was from some blow-by getting past the plugs. I might have now just confirmed that this is actually the case.
Before my 10-hour service, I was getting water on top of my clean-out plugs. No big deal... and I would just remove the plugs and let the water drain after ever outing. After I had my 10-hour service, I noticed the dealer coated the clean-out plugs in bees wax (aka a toilet base gasket). After the 10-hour service and the bees wax around the clean-out plugs.... no more water on top of the clean-out plugs.
As I got closer to the 30-hours I started getting water on top of the clean-out plugs again and I could see the bees wax was starting to fade away around the plugs. I was using some waterproof lube on my clean-out plugs that I also had used use on pool pump o-rings before the bees wax. Trouble with that lube is that it is tough to get it to stay on the clean-out plugs.
I have now switched to bees wax and it sticks much better to the clean-out plugs and also lasts longer. I also stopped getting water on top of my plugs again so it appears the bees wax not only lubricates the plugs but helps keeps them sealed to prevent any blow-by from the pump. At least that's my theory of how water gets on the tops of my clean-out plugs on the 275.
When I start to see water on top of my plugs again, that is going to be my singnal to coat the plugs with bees wax again.
