markrona
- SX
I have a 2012 Yamaha SX210, 280 hours with the check engine alarm on Port engine only. Diagnostics are fine, runs great, engines checked out fine, mechanic ran codes and is only finding one ‘unknown’ code, he has reset it and it comes right back. He checked all key wires and didn’t see anything odd. We did see the N2k and speed comm error when resetting using the key cycle method to reset the check engine light.
I replaced battery, terminals looked good, I did recently replace radio head unit but had it for about 20 hours last season and no issues. The alarm did start right after dewinterization - I just figured it was low voltage so I replaced battery. In other posts about this topic I see that the transducer has been a problem. While I am getting speed (mechanical on this model) and water temp, I forgot to check the depth gauge. So my questions - is only the port engine a clue? where is the transducer? If it was a transducer would the alarm show on both engines? What could have come loose from the radio that may not be obvious behind the radio? I have a cutoff switch for the battery, it’s clean but could this be an issue? Any other ideas would be appreciated, the mechanic spent about 3 hours and could not find it. I have been bragging about how efficient and easy this boat has been for tool long and it caught up with me. Thanks in advance - Mark
