Another Hydroturf horror story
RadioWaves
Benton missouri
Chaparral
I got in on the year end sale on Seadek from JBP and was stoked to get the old Hydroturf off, I figured it would be a 1 night project seeing as this is the 3rd Yamaha I have done this to and never had a problem. WRONG.
I started on the lower swim deck and the top of the piece came off fine but about a 1/4 of the way down it was stuck tight. Got as much off as I could then went to the next level on the boat fearing the worse but it pulled up in 1 piece with no glue left on the boat WHEW! the anchor locker came off just as easy but the piece over the head stuck just like the swim platform.
I tried all of the chemicals suggested on this forum and nothing would touch it, most seemed to make it worse, as did heat. Finally bought a pinstripe removal wheel and worked like a charm. Slow but took off the remaining Hydroturf and glue. Took 2 wheels and several hours to do the platform and head area.
Now just waiting on the weather to warm up to install the new Seadek.
Also removed all of the warning stickers while I had the adhesive remover out.
Ugh I had the same issue it I will probably have nightmares while I sleep tonight now that this has brought back the memory.
I found when I did mine that cold worked wonders. I did it when it was like 35 or 40 degrees out and it came off relatively easily and in one piece. I know people like to try heat, but it never seems to work out well from what I have seen...
Oh no! Not the warning stickers! Those are comical and draw good conversations!
I tried leaving the boat out in sub 20's temps, didn't help. Really odd that some of it came off with no problem and some of it stuck.
Mel, it really is unbelievable how many people actually read those warnings and they do get a kick out of them, but it does get old after the hundredth time
I bought 1 from Amazon but needed another, local NAPA store had them in stock.
Tip; go slow. While figuring out how to use the wheel I actually burned the gelcoat by spinning too fast and holding it in 1 spot for too long. It works better at a low RPM. Luckily the burned spot will be covered up by the beautiful new Seadek!
How about that! Yes, they are a little dangerous, but I had spent some time fighting the glue without the wheel, with no luck, so it seemed extremely helpful at the time.
(How could I miss it, there's a picture of you using it, sorry for missing it)
Glad the project is almost done.
Very cool...not heard of this tool before....hope I never have to use one!
The yamaha side logo lettering on my 230 was pitted by salt and sun, and my warning stickers were baked on. They had to Go.
This wheel made easy work out of an otherwise painful and time consuming task.
I hate to be a spoil sport and you hear too much of this legal crap anyway, but if you were to have an accident the opposition lawyers would be all over this. (removing the warning stickers)
Now back to your regularly scheduled programming.
@RedBarron55 , those stickers are actually there to protect Yamaha, not the owner. An individual owner is going to be responsible if anyone is injured on his/her boat...and liability insurance is the best bet. Now back to humorous...do all your pillows and furniture still have those ugly “do not remove under penalty of law” tags on them? :winkingthumbsup"
...End hijack
Can any of you describe how this eraser wheel works and what makes it difficult? I am curious to know if you could safely remove the 3M clear bra stuff with it. So you “erase” right through the material? Or is it more about erasing adhesive after removing the material?
I have done both. ( Killed a few labels with no mercy, zero prior effort.) Just move around a lot so you don't burn anything with heat from the friction. Power tools are great at saving effort, but you can also break things faster. Take it easy while you figure it out. With love and care you have a chance.
I am not worried about the warning stickers, If I lived my life worrying about being sued i would never leave the house. If there was even the smallest chance that one of those stickers being in place would keep me or my crew safer I wouldn't have touched them.
Mel, I believe the wheel works because of friction. Being rubber it is very soft but very sticky, it grabs on to anything including leftover Hydroturf and disintegrates it. Most of the material you see on the back of my boat is the spent rubber from the wheel.
I was considering trying to remove the “Diamond Shield”, a clear bra material, onthe front of the motorhome. There is a clear bra company that had a you tube on it and said not use a wheel on diamond shield. But I can’t see why not.
I have to agree with you about being always worried about being sued, but my fear would be that if there were an accident the removal of all warning stickers would indicate a lack of concern about safety.
No sticker will keep you safe nor will it keep the lawyers away, but a career of worrying about these things for OSHA and MSHA and the company safety wonks it is hard to come up with a good answer if someone asked you in court why you removed the warnings.
By the way I cut the pillow and mattress tags off instead of tearing them since I fear the release of dangerous fluff if the seams rip out instead.
I just can’t believe that I consider myself a member of a group of people who are such outlaws. Removal of warning stickers and mattress tags? What’s next? Putting the TP roll on backwards so that it feeds down the back? :) Say it isn’t so.
Disclaimer
Do not remove this disclaimer under penalty of law.
For optimum performance and safety, please read these instructions carefully.
Void where prohibited. No representation or warranty, express or implied, with respect to the completeness, accuracy, fitness for a particular purpose, or utility of these materials or any information or opinion contained herein. Actual mileage may vary. Prices slightly higher west of the Mississippi. All models over 18 years of age. No animals were harmed during the production of this product. Any resemblance to actual people, living or dead, or events, past, present or future, is purely coincidental. This product not to be construed as an endorsement of any product or company, nor as the adoption or promulgation of any guidelines, standards or recommendations. Some names have been changed to protect the innocent. This product is meant for educational purposes only. Some assembly required. Batteries not included. Package sold by weight, not volume. Contents may settle during shipment. No user-serviceable parts inside. Use only as directed.
Do not eat. Not a toy.
Postage will be paid by addressee. If condition persists, consult your physician. Subject to change without notice. Times approximate. One size fits all. Colors may, in time, fade. For office use only. Edited for television. List was current at time of printing. At participating locations only. Keep away from fire or flame. Avoid contact with skin. Sanitised for your protection. Employees and their families are not eligible. Beware of the dog. Limited time offer. No purchase necessary. Not recommended for children under 12. Prerecorded for this time zone. Some of the trademarks mentioned in this product appear for identification purposes only. Freshest if eaten before date on carton. Subject to change without notice. Please allow 4 to 6 weeks for delivery. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. Slippery when wet. Substantial penalty for early withdrawal. For recreational use only. No Canadian coins. List each check separately by bank number. This is not an offer to sell securities.
Read at your own risk. Ask your doctor or pharmacist. Parental guidance advised. Always read the label. Do not use while operating a motor vehicle or heavy equipment. Do not stamp. Breaking seal constitutes acceptance of agreement. Contains non-milk fat. Date as postmark. Lost ticket pays maximum rate. Use only in well-ventilated area. Price does not include taxes. Not for resale. Hand wash only. Keep away from sunlight. For a limited time only. No preservatives or additives. Keep away from pets and small children. Safety goggles required during use. If rash, irritation, redness, or swelling develops, discontinue use. Do not fold, spindle or mutilate. Please remain seated until the web page has come to a complete stop. Refrigerate after opening. Flammable. Must be 18 years or older. Seat backs and tray tables must be in the upright position. Repeat as necessary. Do not look directly into light. Avoid extreme temperatures and store in a cool dry place. No salt, MSG, artificial colouring or flavoring added. Reproduction strictly prohibited. Pregnant women, the elderly, and children should avoid prolonged exposure to this product. If ingested, do not induce vomiting. May contain nuts. Objects in mirror may be closer than they appear. Do not use if safety seal is broken.
Apply only to affected area. Do not use this product if you have high blood pressure, heart disease, diabetes, thyroid disease, asthma, glaucoma, or difficulty in urination. May be too intense for some viewers. In case of accidental ingestion, seek professional assistance or contact a poison control center immediately. Many suitcases look alike. Post office will not deliver without postage. Not the Beatles. Products are not authorized for use as critical components in life support devices or systems. Driver does not carry cash. Do not puncture or incinerate. Do not play your headset at high volume. Discontinue use of this product if any of the following occurs: itching, aching, vertigo, dizziness, ringing in your ears, vomiting, giddiness, aural or visual hallucinations, tingling in extremities, loss of balance or coordination, slurred speech, temporary blindness, drowsiness, insomnia, profuse sweating, shivering, or heart palpitations. Video+ and Video- are at ECL voltage levels, HSYNC and VSYNC are at TTL voltage levels. It is a violation of federal law to use this product in a manner inconsistent with its labeling. Intentional misuse by deliberately concentrating and inhaling the contents can be harmful or fatal. This product has been shown to cause cancer in laboratory rats. Do not use the AC adaptor provided with this player for other products.
DO NOT DELETE THIS LINE -- make depend depends on it.
Warranty does not cover normal wear and tear, misuse, accident, lightning, flood, hail storm, tornado, tsunami, volcanic eruption, avalanche, earthquake or tremor, hurricane, solar activity, meteorite strike, nearby supernova and other Acts of God, neglect, damage from improper or unauthorised use, incorrect line voltage, unauthorised use, unauthorised repair, improper installation, typographical errors, broken antenna or marred cabinet, missing or altered serial numbers, electromagnetic radiation from nuclear blasts, microwave ovens or mobile phones, sonic boom vibrations, ionising radiation, customer adjustments that are not covered in this list, and incidents owing to an airplane crash, ship sinking or taking on water, motor vehicle crashing, dropping the item, falling rocks, leaky roof, broken glass, disk failure, accidental file deletions, mud slides, forest fire, riots or other civil unrest, acts of terrorism or war, whether declared or not, explosive devices or projectiles (which can include, but may not be limited to, arrows, crossbow bolts, air gun pellets, bullets, shot, cannon balls, BBs, shrapnel, lasers, napalm, torpedoes, ICBMs, or emissions of electromagnetic radiation such as radio waves, microwaves, infra-red radiation, visible light, UV, X-rays, alpha, beta and gamma rays, neutrons, neutrinos, positrons, N-rays, knives, stones, bricks, spit-wads, spears, javelins etc.).
Other restrictions may apply. Breach of these conditions is likely to cause unquantifiable loss that may not be capable of remedy by the payment of damages.
This supersedes all previous disclaimers
Entire contents (c) 1999 by Our Group, Inc. This disclaimer is protected by copyright and its use, copying, distribution and decompilation is restricted. All rights reserved. No part of this disclaimer or any attachments may be copied or reproduced, stored in a retrieval system, or transmitted, in any form, or by any means, optical, electronic, mechanical, photocopying, recording, telepathic, or otherwise, without the express witnessed and notarised prior written consent of the all holders of the relevant copyrights.
The information contained herein has been obtained from sources believed to be reliable. However, no warranty as to the accuracy, completeness or adequacy of such information is implied. No liability is accepted for errors, omissions or inadequacies in the information contained herein or for interpretations thereof. The reader assumes sole responsibility for the selection of these materials to achieve its intended results. The opinions expressed herein are subject to change without notice.
The information in this document and any attached files is strictly private and confidential and may also be privileged. It is intended solely for and should be read only by the individual(s) or organisation(s) to whom or which it is addressed. If you are not the intended recipient, or a person responsible for delivering it to the intended recipient, notify the sender by return, delete the message, and destroy all copies of the email and associated files in your possession; you are not authorised to and must not disclose, copy, distribute, or retain this message or any part of it. It may contain information that is confidential and/or covered by legal professional or other privilege (or other rules or laws with similar effect in jurisdictions outside England and Wales).
We have an anti-virus system installed on all our PCs and therefore any files leaving us via email will have been checked for known viruses, but are not guaranteed to be virus free. We accept no responsibility once an email transmission and any attachments have left us.
No part of this message is intended to form any part of any contract. The views expressed in this message are not necessarily the views of my employer, and the company, its directors, officers or employees make no representation or accept any liability for its accuracy or completeness, unless expressly stated to the contrary. This message is not intended to be relied upon without subsequent written confirmation of its contents. This company therefore shall not accept any liability of any kind which may arise from any person acting upon the contents of this message without having had written confirmation.
This document originates from the Internet, and therefore may not be from the alleged source. If you have any doubts about the origin or content of this document please contact our Support Desk.
Moral:
This mail could have come from absolutely anybody masquerading as the sender, could have been read quite legally by the State under the RIP legislation, by the security services of any other state through which the data passes, by the sender's or receiver's employer on the pretext of protection of business interests, and read or altered by anybody working at any of the infrastructure services involved in its transmission. Given that internet routing is complex and adaptive, you don't even know who most of these parties are. Why not use encryption next time?
