Another sub question...
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
242X E-Series
I keep looking at all of these sub woofer posts and cant help but want a little more out of my system. Right now it sounds good but I am searching for the perfect bass response on the water. Right now I have 1 12" sub under the port cabin seat and one under the starboard cabin seat. I play the one under the starboard seat all the time and can switch on the port sub when I want. I do not want to cut holes in my boat for porting or for a different sub so my question is, @David Analog , I was looking on the earmark website and seen 2 10" subs mounted in the helm closet on an older Ar230, how did this sound? I figure I could just open up the helm door when I really wanted to get the sound out and this would be my "port" without cutting holes. I did a little sketch of the box I would build to go in there. Would this be a good option? TIA
By the way I did remove my plastic try on the port side where the sub sits and it made it sound like crap, maybe the sub had too much gain on it and I didn't know due to being in the compartment?
Ok I think I figured it out. I went out in the boat and looked at my amp to the sub and it was turned WAY up. I must have looked at it wrong when I put it in over the winter. Turned it down to where it needed to be and then took out the pocket again and it sounded much better this time. So I think I am just going to install a vent right there.
As much as I hate to do it, I plan on cutting a vent as well
