DaveShip55
Previously to this 255X, I owned an AR230 for 16 years, and yeah the clean out tubes would often be full of water, it was perfectly normal…. Usually from water coming up on the stern platform when coming to a stop… and it would be both tubes filled with water, and of course some water would make it into the bilge….. no biggie!
But with this new 255, I’ve noticed that when cruising along for a decent period of time (never stopping, therefore no water coming up on the stern platform, as well as the clean out platform is much higher on the 255 than my old 230, so water really doesn’t make it up that high when stopping.) But anyways, while cruising I’ll notice the bilge will kick in about every 15 minutes or so, and pump out quite a bit of water….. also when I do eventually stop, only one clean out tube will have water in it.
These new plugs are different than my old style, (which I like better), but is it possible for one of the plugs to be leaking a tad while under way, thus letting water in the tubes, making it into the bilge?…. I mean, I don’t think I’ve ever heard of a plug ‘leaking’?…. Just not sure what would be causing this?
Side note, if I’m just floating or beached for a long period of time, the bilge pump never pumps any water out, so I’ve kinda ruled out a regular water type leak….. only seems to happen while under way….
I’ve looked in the engine compartment while under way, and I don’t see an engine leak, at least not that I’ve seen….
Thanks in advance for any insight!
-Dave
-Dave
