Anti-pooling poles - trailering - yamaha factory cover
jokirkev
It sounds like this is debatable??
Should I use the anti-pooling poles when trailering assuming it will NOT rain. Thanks all for your input! Have a great day!
I have now seen a post where it reads don't use the poles at highway speeds - which I have always done...then add the poles once you stop. What if you are taking a long trip and it begins pooring?! It doesn't seem to be worth the risk to not use the poles?
I don't use the poles myself. Felt like the stretch on the cover wasn't worth the anti-pooling function.
I run the straps in place, poles out, and a custom cut pool noodle over the windshield to keep the windshield bumper from poking into the cover. Going on season 4 with this cover.
When moored or parked outdoors and covered, it's the same setup but poles in.
I've driven through a ton of rain with the cover on. If you're "at speed" on the interstate or backroads the pooling isn't really an issue. Wind will blow the water out/away. If you're going slow or stopped then water will pool in the bow area. IMO the pooling when stopped is less of an issue than the stretching at speed.
I don't think there is a "right" answer here. Do what works for you, and enjoy the boat. Poles in/out isn't going to significantly reduce or enhance the life of your cover. UV and physical damage is far more likely to end it's life than stretch from poles in or pooling from water.
Debatable, yes. I have been towing with my poles installed and now have considered installing beach balls instead, after reading suggestions on the forum. I love the cover, but it's a PIA to put on and off every trip. When on the backroads, I leave the poles out. I'm still debating what's the best thing to do.
I like the pool noodle idea and plan on installing them. I'm going to assume you just slit them down the middle and then cut to length?
I left mine full length, and cut a notch to go around the window bumper. Then a single slit lengthwise to slide on the windshield.
Also, get a larger diameter noodle to start. I got a small one initially and it crushed down after one season. Got a big one and its been working for a few seasons now.
Thanks, I've already purchased some noodles, but will look for some larger ones. I haven't come across any larger noodles, yet.
Did he recommend those for the rear as well? One in the front, one in the rear?
Just the front, between the bow seats. I’m thinking this will be a good fit on my boat as the center console seat will keep them up front.
They hold the cover up while parked or trailering. The best part that I can see besides the fact they give a large rounded surface for the cover to ride on, is that they are deflated and stowed with minimal space required…
No poles for me. I have been caught in plenty of downpours. If water really starts to pool, hitting the brakes to slow down will slosh it forward to spill out. When parked and expecting rain, I will install poles. I also use large split noodles on the top of the windshield.
I installed mine today and I must have the big ones. They fit snug and no way are they wearing out anytime soon.
No, both of those for the front, one on each side of the bow seating area. I got a 5' ball for the back. It's the bump in the middle. It may or may not be needed, but it makes me feel better
img_20200803_185121199_hdr-2-jpg.144332
Hitting the brakes does, indeed, slosh water out of the front. Is that possible if you're on a long drive? Maybe, maybe not. At 8 lbs per gallon, I'd guess there's at least 4-5 gallons of water if you're caught in the rain. I wouldn't want to put a 40 lb weight on my cover for any amount of time, given the several hundred dollars that a replacement cover costs, and the shortage of them at various times. I found the two balls to be an awesome solution to my problem. I don't have a tube that we use, but someone else mentioned that if you take the kids tubing, turning that over in the bow area is another great solution to this. Either of these ideas seem to have far less potential to stress the cover than the anti-pooling poles, or at least spreads it over a far larger area than the single point of contact from the anti-pooling pole system. Yamaha also made a point to mention not towing with the anti-pooling poles in place above certain speeds. Water seems to shed better with the balls than the anti-pooling poles, as well. Here's the view after inflation, make your decisions based on what your goals and opinions are. I like boobs on my boat.
img_20200803_185050541_hdr-2-jpg.144331
I like the boobs, already ordered a pair. Also, I like the noodles on the windshield frame as well. This is the first time I heard anout the 60” ball in the back. Should I get some snakes too? Lol
Snakes are only if you park under or near trees, as shown in the pics.
I always get comments on the snakes, mebbe I should put that info in my profile - "snakes are bird repellent"
Eventually, the rhinoceros gets hard to explain. "Well, it started with crickets in the bilge, so we got some frogs to take care of them, then the frogs got out of hand...next thing you know, I'm buying Rhino-Chow. Any tips for getting rid of a rhino?"
The wife just bought another big pool noodle for use as a blade sheath on our weed cutter. She said Walmart and Big Lots have them in our area. Not sure about your area.
Very thankful for so many knowledgeable comments. Thank you ALL - have a GREAT boating season!!!
You may want to cover that Navi light, it's ready to pop through the cover. Just an observation.
Which trailer jack is that? Any install issues?
@RobbieO id'd it right, I've got the 750.
The only install issue was that I kept falling to the left without all the cash to counterbalance me on the right...and it's heavy as all get out
