4x15mph
- Downingtown, PA
Low compression on cylinder #2 after last weeks debacle and overheat on the Delaware. 15 PSI lower and I saw slight scoring in the cylinder through an inspection cam. Started the tear down today and will rebuild the top end which I have been itching to do for a couple of years now.
Please respond if you have any experience with the 2 strokes in case I have questions.
Here is the piston from the exhaust port view.... seems like the heat glazed it although the top of the piston looks fine and it didn't melt. I am in too far already though and will do the rebuild
