Any info on the K&N oem RIVA air filter '18 242x?
jacoviii
Independence Mo
255XD
So looking to see if anyone has tried the Riva K&N oem replacement filter. Is there any performance to be had?
I think someone found a k&n that fit.
I'm running the Riva filters in my 2017 242X. No noticeable performance gains from the filters to speak of. But I installed them at the same time as the ribbon delete and my L13 pump cones.
There is no performance gains with any a/m filters they do give you a spark arrestor in case you remove the factory ribbons
How many modern FI motors have you had back fire and burn a air filter?
Not a one, but in a marine application they are required. Not that anyone would check.
The Riva filter is coast guard compliant i believe.
I am sure if you had an engine fire and if your insurance company investigated it thoroughly they could deny any claim if you didn't have some sort of spark arrestor.
