- Corinth, TX (DFW)
I was going to try to do a good deed and help my neighbor with a bad sprinkler solenoid but we can't locate the valve. I was going to rent a normal transmitter that seemed easy enough to use but when they brought it to the counter they found out it wasn't working correctly so they gave me a higher end model usually used for utility lines but it was supposed to do the same thing.
I can't make it work and the instruction manual is very limited along with youtube's from the mfg.
Just throwing this out there hoping to be able to do something with it tonight, maybe @zipper or @Mainah
The transmitter is a gen eye G3 (with only an on/off and hi/low frequency button) and the stick is a gen eye hot spot locator,
I believe I have the transmitter hooked up properly, grounded and to the valve line at the control box and it has a loud constant hum from the transmitter. I'm looking for the line but even finding it on the outside of the wall is difficult.
hot spot manual http://www.drainbrain.com/instructionspdf/Gen-Eye Hot Spot Instructions 8-13.pdf
pictures to follow from my phone in just a minute,
