Anyone use carabiners for anchor?
Shookie
Jetboaters Commander
Cary, NC
242 Limited S E-Series
Does anyone use a heavy duty carabiner instead of anchor shackles to connect your rope, chain, and anchor?
You can get carabiners rated for over 5000 pounds and a lot of anchor shackles I’ve looked at are much less than that so I’m just curious if there’s a good reason why you wouldn’t want to use them…
I ve used both and have lost anchor due to shackle bolt was loose.
I like using the "C" that threaded locking opening.
A carabiner with that weight capacity (typically has a self locking gate) has a larger opening than an anchor shackle; and therefore, it could hang up a little more easily on rocks, logs and etc. However, I think in most cases for most people it would not matter which you used.
Yep, I lost my original anchor because the shackle bolt came loose. I didn’t have it locked. So when I bought my new anchor I bought two anchor shackles to go with it but they wouldn’t fit through the chain so I need one more (to attach to rope) and that got me thinking about a carabiner instead.
Use S.S. seizing wire with a shackle. A few wraps thru the hole and back to the shackle and the bolt will not back out.
I use a stainless carabiner to clip the anchor line to the bow eye when anchored. I still tie it to a bow cleat and just clip the line to the bow eye. I find that when the line pulls from the center the boat does not swing as much.
I agree I think it swings and rides better attached to the bow eye, especially when its rough..I use this below...great for adjustment and attachment..
Yesterday I switched out my anchor line (1/2" to 3/8") and had red loc-tite on the shackle pin that needed to be removed. I had to put it in a vice and then really lever on it to get it off. I think that's going to hold it but lI ike the zip-tie and bailing wire through the pin hole, going to add the zip tie this afternoon
Gonna order a heavy duty carabiner for it.... will post once I get it.
I would suggest you use one like this. It is almost as easy to use, less expensive and far more secure that a carabiner.
A carabiner will probably work fine, assuming it can hold up to marine use. They are just made to open and close easily which isn't really needed for this application.
I bought these carabiners for another purpose, but they would work well - 5K rated, aluminium, self-locking and less than $20 for 3.
  • Favofit UIAA Certified Climbing Carabiners (Certificate No.: USA 20-5611), 3 Pack, 25KN (5620 lbs) Heavy Duty Large Locking Carabiner Clips for Rock/Ice Climbing Rappelling Rescue Swing etc.
Roll over image to zoom in
  • ✅UIAA Certified Heavy Duty: This climbing carabiner is UIAA certified (Certification No.: USA 20-5611) with weight limit at 25KN (5620 lbs) for major axis, and at 7KN(1573 lbs) for minor axis and locking gate
  • ✅Auto Locking Caribeaners: these aircraft grade aluminum climbing carabiners are great for all activities like rock climbing, ice climbing, rappelling, rescue, swing, aerial yoga, camping and hiking etc.
  • ✅One Hand Operation: with the twistlock design, you can easily operate this rock climbing carabiner with one hand. With a simple twist to the barrel and push against the spring load, it will open. Once you release the spring load, it'll lock automatically immediately
  • ✅Super Lightweight: Weighs only 2 oz each, these ice climbing carabiners are prefect for minimizing the weight of your gear during any adventure
  • ✅Durable and Rustproof: Made of aircraft grade aluminum, you'll enjoy using these durable and rustproof large climbing carabiners for long time
This is what I use for my rear SandShark anchor. I use a 50ft line and it makes it really easy to adjust for the changing tide. I attach it to the transom strap mount. Holds 8000 lbs I think 7C5C0C7B-8124-490B-B11D-ECEC8E7619B3.jpeg
How do you attach the line to the carabiner itself? Any particular knot?
I use the Danik to connect anchor rope to bow and stern eyes. Makes for easy adjustments. Worth the money for sure.
