Mbutters
I have a 2015 supercharged ar192 that is sputtering after pulling a tube. I start it and it sounds like it is choking on fuel. It will clear up and run normal after a it of low throttle operation. The boat has never pulled the rpm or speed that has been described here.
I am not sure if the problem happens after getting out o the throttle or what. I have checked that the supercharger does not spin both ways, and the piping from the supercharger and intercooler seem fine.
I don't see a maf or o2 sensor on this boat, does it run on throttle position and rpm?
