AR 192 - Starboard Addition of Access Hatch
ArmyChief
North Port, FL
Thanks to @Joe Covelli's post on adding a STBD access hatch for more storage & easier access to electronics/cables.
https://jetboaters.net/threads/sx192-add-access-hatch-to-the-helm-compartment.2869/
Here is my write-up of installing on our new 2015 AR192.
First, start off with the hatch: T.H.Marine-HDS-1317-2-DP (avg cost is $70-75)
You'll need 4200 sealant, a device to cut the fiberglass (I used a rotozip), stainless steel screws/washers/nylon lock nuts (I bought the big $119 kit from West Marine), blue painters tape, half-round file (Harbor Freight ! :) ), level & a black sharpie.
Step 1:
I wanted the new STBD hatch to be approx the same distance back from the bow as the factory port hatch. It came out to about 6" to the edge of the port hatch.
Next, I needed to take into consideration where the hole needed to be PLUS the edge of the new hatch. that came out to about 1 1/4"
So, that means the forward edge of my hole should be about 7 1/4" from the seat edge (dimple edge like shown above in first picture). I measures the height of the bottom edge of the port hatch, added the additional 1 1/4" and determined the bottom edge of my proposed hole location. Then I took the template (part of the box, see first pic above), taped up the template (leveling).
Traced around template with sharpie and then cut out (scariest part....)
Note: cut the corners in a little and polish up with file. If you follow template exactly, you will need to use machine screws and washers in the corners.
Remove blue painters tape
File and dry test fit.
Mark screw holes with sharpie.
Drill pilot holes (smaller than screws if using tapping, larger if using machine with nylon lock nuts)
Apply sealant (don't use too much :) )
Screw in hatch
Ta Da!
In my opinion this should be included from the factory. It adds much needed storage and easier access to your electronics.
Plus, having the hatch allows easy access to the next item installed...the sub-fuse panel :)
^^^ This is another write-up..coming soon :)
Thanks and hope you enjoyed the write-up
Thanks. This is an incredibly useful mod. I am surprised that Yamaha does not include a hatch from the factory.
Nice write up and pics!
Only hint to add: if you are using tapping screws, it would be good to also use a countersink on the holes before putting in the screws to minimize chipping of the fiberglass. I learned this one the hard way installing my antenna...
No need, regular pan heads go through the holes along the frame of the hatch. Just pre-drill holes as normal with a slightly smaller but.image.jpg
Looks great @ArmyChief well done. I know what you mean when you say "cutting the hole" was the "scariest part". I'm sure it felt awesome when you fit the new cover in that huge hole and it fit perfectly!!! WHEW!! ;)
Lol, I'm very handy, been in the maintenance field for 30 years....even the wife was worried. However, the first weekend out afterwards...she LOVES having the extra room :)
This will for sure be on my next to do list! I wanted to do it this year but ran out of time before putting the boat in the slip.
@ArmyChief Will the 13x24 fit?
I think you can get 7" more without an issue. I'll measure from the inside when I get home. However, not sure it's needed or would be beneficial. If you look at my pic of the installed sub fuse panel inside. If the hatch were 7" higher, all you'd see is the back of the wiring. Not to mention I think I like having the extra fiberglass for structural support.
Looks great. Thanks for the write up. Going to do this soon.
Thanks @ArmyChief because of the included pictures I added this to the FAQ list
Step 1:
Screw in hatch
Ta Da!
Good job Army Chief, your install came out perfect. Enjoy the extra storage.
No need, regular pan heads go through the holes along the frame of the hatch. Just pre-drill holes as normal with a slightly smaller but.View attachment 23459
Do you have any close-up images with the door closed.?
I curious how close the white from the after market hatch matches the interior gel coat?
A close-up of the color match would be great if not too much trouble.
I've found that the same hatch manufacturer TH-Marine also offers some fairly small glove compartment boxes as well.
I'm considering installing the same hatch as yours (maybe slightly lowered) and then the small glove compartment above it if space allows.
One day when the newness wears off my boat, I'd like to do this mod. It should have come this was from the factory.
Two more questions about this mod...
1. Do you think there is room above the new hatch to horiztonally install a 7x14 glove compartment matching hatch?
2. Really like the look of the hatch door. Is there a size from same manuf to maybe replace factory port-side door?
Wondering if there would be this kind of space under the helm for the 190...I like this idea, a lot!
