AR 250 SIDE PANELS
ddonoso
CT
Hey Guys,
I need to replace the USB charger on my Brand new AR 250, does anyone know how to remove the port side panel?
No, but I can tell you that if you have access to a 2nd person, you can do this WITHOUT removing the panel. My 17 yo son and I replaced our OEM single port with a multiport and digital readout. I worked from the front, and he was able to reach the back side from within the bathroom compartment. You can reach the wire by worming your arm around the interior panel at the aft end of the bathroom, and then follow it up to the USB receptacle.
Need your helper to have reasonably long, but not body builder arms though.
any luck removing the panel? I'd like to remove the starboard side panel and install a 12v outlet
Anyone successful at removing the panel?
