Gooch
- Stoddard WI
I have a question about steering difficulties on the AR250’s. We had the boat out this weekend and I noticed it was much harder to steer to the right than the left While under heavy throttle. I have installed the Cobra Jet steering so I’m curious if that could be the culprit. I had it at the dealer and worked with the tech to check the steering cable and the cables seemed to be correct. I also took the fins back off and double checked that the novels are even. Is this something inherent with these boats, or could I have installed something wrong?
Also to clarify I had a passenger upfront on the port side and another passenger in the port cockpit seat. Could the weight distribution cause an issue?
