Bviasource
Hello everyone,
Hope someone can help me. I been reading the forums and trying what has been suggested but to no avail. I can be cruising along and all of a sudden the boat will slow down abruptly to a crawl , the engine will make noise and run rough so I'm thinking it's not running on all four cylinders, the engine check light and engine comm error appear. The last two months all I had to do was shut off the engine and it would start back up and it would be good again. The problem is getting worse as now it's happening more often and once I cut the engine off the boat won't have any power to start again but I have power for lights blowers ect. I have to turn off the battery then back on and it will start right up and run fine. I have no yamaha dealers near me that work on jet boats so I'm screwed for professional help. I'm not getting any codes. I did put in a transducer replacement wheel ( for speed sensor) and when I did that I must have broke the depth finder because it stopped working the same day. This problem started a month after that repair and I have had a dead battery twice since then.
So since this engine comm error came up I changed the battery, cables, oil and plugs. These are the things I found in threads here but made no difference. Is it possible that the transducer is cause all my headaches?? See the video of the comm error
All help is much appreciated
