On my '17 it is removable; but it'll take some effort to get there.
Have to unbolt the support bar from inside the port aft storage, and the forward port storage areas. Then there are two vertical bolts that are VERY hard to reach that hold the seat down to the port gunwale.
These two screws require some long arms, or small persons to get to:
This support isn't hard to reach for a normal size human:
This support can be reached easily as well through the forward storage door:
SO.....you'll need to remove the two screws in the gunwale (blue circle below), and the two supports (and bar) in red below.
