SantaFeTrailer
- Santa Fe, New Mexico
New to me 2013 AR192. 1,300 feet lake, 45 degree air temp, 54 degree lake temp, only getting about 6,000 RPM and high-20's on the speedometer.
Impeller and wear ring are in good condition, with clearance just about at 30/1000
Throttle control adjusted properly (edit: maybe 1/4" from stop seems OK?)
Supercharger clutch checks out good
Oil is at the top mark, but not over
New plugs on order
edit: checked the air filter, clear of oil
When I removed the impeller and wear ring I noticed that there was no sealant at all. I will use sealant when replacing, but could this be making the difference?
I want to make sure I have my bases covered on what to try, since I am an hour from the lake. However, I have been sitting in my driveway making boat noises, so at least I have that!
Thanks!
edit: for the sake of completeness, we had two of us (say 375 lbs total) and almost nothing else other than pfd's and a fire extinguisher. No idea how old the gas is. Do boat yards usually fill the tank on used boats for you, or has it been sitting since the last time the boat was used? (2013 with 45 hours on it, so it could have been a long time) Maybe I will siphon it all out into my old pickup and fill it with fresh.
New plugs on order
Thanks!
