AR192 Speed Sensor
travalab
Boston, MA
AR192
My speedo stopped working the second time out. It stays at 0mph until we are at full speed then jumps to ~30mph. I found the paddle wheel under the boat. It does not seem to be spinning freely, I am assuming this is the culprit. My question is, how do I go about cleaning it? I only had a chance to look at it briefly before putting the boat away for the week, but I didn't see anything externally wrapped around it or anything. Is there a way to remove it to clean, or is there a trick I need to know?
Thanks!
I noticed my speedo wasn't working the last few times out, I also found my paddle wheel hard to turn, I imagine some sand probably got up in there. I haven't been in too much of a hurry to get it back running because I can get the GPS speed in the digital readout, but it would be nice to see that big needle on the left of the dash doing something :confused:
If you decide to tackle cleaning it out, let me know how it goes. I won't be back to my boat until Saturday and any input would help. Thanks!
It's a very common problem, usually there are tiny string like pieces of weeds wrapped around the pin that the wheel spins on causing friction, take a very close look I doubt it is sand. your wheel should have clearance on both sided
I got under it and looked at it the best I could but couldn't see anything on the wheel or the pin. I turns a half turn smoothly then binds up. I am sure there is something in there but I can't see it. I might have to bring to to a dealer and have them look at it. I was going to try to remove it to clean, but after messing with the safety wire, I decided I was in over my head.
Do the Ar's have GPS digital speedometer from the factory or is that something you added? I have been thinking about adding a GPS speedometer for better accuracy while towing.
there is a digital readout on the gauge but to be honest I'm it sure if it's gps, it seems to mirror the analog gauge which stays at 0mph until we are at full throttle and then the needle bounces around between 20-25-30 mph
Nothing I added, I believe it's part of the 192 upgrades. I haven't looked into it too much, since I'm never really concerned with how fast I'm going. I generally just find a comfy cruise speed and set the cruise control.
I just ordered a replacement paddlewheel for my 190. The speedo works on and off. The original dealer sent me an email telling me it was cheaper to change the wheel then the whole transducer assembly.
Andy
"Found that Yamaha only sells it as a assembly, did a little digging and found the paddle wheel is a Airmar # 33-113 available online for next to nothing."
Jim Tammen
Patsy's Bay Marina
I ordered from explosive motorsports
Airmar 33-113 Paddle Wheel For: B44 Style Bronze Thru-hull Tri - 33-113
33113 Quantity (1) $23.48 USD
Here's a link to my repair.
https://jetboaters.net/threads/ar190-speedometer-paddle-wheel-replacemnt.6342/
