stevenk2
Just had my AR195 down to Havasu for its' first outing - overall, highly impressed with the boat, both from operational and performance standpoints. Had zero issues with the boat itself, even after the 1100+ mile journey down there (and all of the associated bumps/shakes/rattles it took on I-5 on the way down). Did the break-in period as specified in the manual, then opened her up and ran up and down the lake a bit with my two kids in the boat. Very impressed with how well it handled, did very well in the chop we encountered, got up to around 45 mph full throttle (hopefully that number improves a bit over time). Overall, she performed like a champ the entire three days we were out on the lake - very happy with my purchase!
The only issue I had was with the Clarion amp I had installed after I bought the boat - since the temps down there were at or over 100 degrees during the day, extended times with the stereo at higher volumes caused the amp to start overheating and cutting out, which required us to power down the stereo for awhile to allow it to cool off a bit. We found that by keeping the volume more at mid-level we were able to run it continuously without issue. I may try playing with the levels a bit on the amp, but I suspect under normal circumstances/temps back here at home, we'll probably not have any overheating issues per se.
I did have a few questions regarding a couple of items though. First off, I did notice that there was some cavitating when I had her hard-over to the starboard side while accelerating (i.e. coming about to pick up a downed skier). I didn't notice this behavior when doing the same maneuver to the port side. Is this normal and/or something to be concerned about? It's not a huge issue per se, since it only seems to occur under that very specific set of circumstances. Second, what are the rules for the bimini top when it comes to hauling the boat? We had it all strapped down and bundled up in the cover up on the tower driving down the highway, but with the wind buffeting and such, I didn't know if it may be a good idea to just take it off and store it in the boat or vehicle when travelling?
Also, what is everyone using to clean the upholstery in these boats? Is there a type of cleaner that works, or is it best just to use a mild soap and water mix? The seats seem to have more of a coarse fabric type covering rather than a regular vinyl, which is likely more durable, but I'm not sure of the best way to clean them without damaging/discoloring anything.
