AR195 Radio Help
SCP1
DeForest, WI
212S
Power button is light up but the radio does not turn on. Seems odd as it worked great the last time I had it out. Any suggestions, the blower works so it’s not the battery. Cigarette lighter works as well.
Did you cycle through the inputs? It may be on an AUX or other input...
The little power button has a light on it which is lit. However the screen / deck is not on if that makes sense.
Does the radio have the removalable face plate?
If it's the clarion it's a known issue, same thing happened to mine, I ended up replacing
Tried the reset button, obviously I didn’t work. I have a hard time believing it’s a fuse as you see a light on the power button. Found the manual it’s not helpful. Anyone know where the fuse is, just in case?
Most aftermarket radios the fuse was on the back on the unit. Take a peek at it from inside the storage locker.
