Ar195
Dylan Todd
AR195
The pins on my Bimini keep shaking out. Anyone been able to fix this problem?
Thanks.. I guess I wasn’t very clear. I was talking about the hinge pins on the Bimini it self that allows it to be lowered and put in a garage. I’ve had them fall out completely under speed. I don’t really see a way you keep them in permanently.
Are you talking about the tower? There are no huge pins on a 195 Bimini, have a pic of what you are talking about?
Yes. The pin should have a little spring on the side opposite the post it is holding. These, right?
That spring pushes the pin back against the hinge so that the hinge cannot rattle up and come through the hole. If your pin and the hole is not lubricated, then the spring gets stuck in the compressed state and the hinge can flip up and release the connection.
So I used to use a little WD40 on mine (until I replaced them entirely with the better connector).
Huh I have never seen anything remotely like that on mine. Are they on the older models?
Oh, sorry! Thought they were the same. Yes, these were what were holding all of the bimini connections on my boat (and they would pop out, just like you describe).
Oh I'm not the one that started the thread! I was just wondering, you are probably right in his case that is more than likely what he is talking about
Oops. My bad... But his year is only 1 off of yours. So he may have what you had rather than these...
This is the pin the is giving me trouble.
Ya mine does have one, never even noticed it. Never had an issue with it obviously, first I've heard of anyone having an issue with that specific part
Giant picture showing the pin.
OK, that is a MUCH MUCH larger issue. This is the forward pivot of the TOWER. Not to be confused with the Bimini. The bimini is just the frame and shade fabric that is attached to the tower.
When I had my tower off, those areas on my tower were machined VERY VERY poorly. There is a snap ring that holds that pin in place, and most likely it's missing do to some crap machining.
Here's what the pin looks like:
It "bangs in" from the inside of the boat towards the outside, then a snap ring holds it in place. If memory serves me right. The orientation of the above picture is for the PORT side pin. The "small end" and O-Ring go towards the INSIDE of the boat, and then the snap ring to hold the assembly in place.
I just walked out in the garage and took a picture of mine. If you don't have this snap ring, then you'll need to get a new one, and replace it.
Here's mine:
Here are some pliers to take them in/out.
Here is an assortment of snap rings. I can measure mine if you like, but an assortment is cheap and will most likely have the size you need.
I'll be happy to take a video of me taking mine apart if you need better explanation.
@Dylan Todd A couple other thoughts......
I'm 99% certain your pins are in "backwards" and you're definitely missing that snap ring.
In unrelated topics......What gets VP racing fuel? I can see the cans in the background :D :D
Agreed. This is the first I've heard of this issue. The retaining ring lands on my tower are VERY much NOT concentric, and are VERY poorly machined at that. I suspect @Dylan Todd had the ring escape, and now has nothing remaining to retain the pins. Hopefully it's a quick/easy fix for him.
Thanks guys exactly what I was looking for. The fuel cans are for the boat ?. I keep mine in the water during the summer and the marina has shit gas.
Here's mine:
Is that a rubber gasket on the end of the pin?
It's a rubber O-Ring, yes.
I can't find these parts on the exploded diagrams. I suspect they come as part of the tower package.
I can pull one of mine and measure if you need me to.
Good call @2kwik4u. I can see the confusion now and agree that snap ring would be missing. I haven't had any issue with my pivot pins, will add that to my routine check list.
Would appear that one of mine is starting to walk out.
