AR195S and skiing
bdartnell
AR195
Hi - I am looking right now at choosing between a Yamaha AR195S and the 212x. My son and wife love to wakeboard ... I prefer to ski. I am about 6 feet - 200 pounds. I am wondering if there are any issues with the AR195S and skiing - particularly in pulling me out of the water when I am slalom skiing - I am getting old and if it takes a long time to pull me out it shortens my ski!
Anyone who has experience - would appreciate hearing from you..
No issues here. I'm 5'9" and 200lbs. Pulls me up from a deep water start on one ski no problem.
Pulling shouldn't be a problem. If you need or think you will eventually need the extra room of the 21' boat, then now is the time to get it. If not the 19' footer will work just fine for you.
I wakeboard behind my 195s and I am 6'1 230. With the SVHO it has plenty of power pulling me out of the water.
Thanks ... appreciate the feedback.
I should add one note though .... If you have like 2 adults and a couple small kids in the boat, you'll be fine. But if you push that up by an adult or two or a couple kids, then the weight of what is in the boat can make it a bit harder to perform a deep water start. It's not impossible, just a bit more work. Once up, all is good. I don't know if the 21' boat would have a similar problem as they have the same or less hp.
I'm pretty sure with 5 people on my boat, the SVHO in the 195S could still pull the rope right out of your hands from a holeshot! I just got back from Wisconsin and had 6 people aboard at 1600' above sea level and hit 44MPH with a full tank of gas. Power is not an issue with the 195S, at least in my experience.
I read here also that the twin engines from the AR210 are excellent for watersports and could be an option to the 195S and closer to that price point as well instead of a 212X.
The 21' AR210 has no issues pulling anything up. I have been fully loaded and pulled up skiers in deep water, 3 person tubes with 3 200+ lb adults in it, barefoot skiers, etc. No issues with power or bogging down in turns. Plenty of low end pulling power. Of course the 212's have more engine, but the price point is higher. The twin engines give you a lot of pulling power.
This is music to my ears...and my pockets, hehe. AR210 is my top choice at this time. Thanks for the direct feedback and shared experience.
@Sugarcharged If the AR210 is what your budget it is at for a new one, you will be very pleased and happy. The 212s is nicer and the engines are bigger but so is the cost. For a mid 40k boat you won't be disappointed. We have had and still are enjoying everything on it. If it wasn't for extended journey's across the Great Lakes I wouldn't be looking to upgrade to the AR250, etc.
Any updates on how skiing is going with the 195? In some of the test videos there appears to be a pretty big rooster tail and there have been some posts that seem to hint at people having trouble pulling up possibly due to thrust of the single jet. I currently slalom behind my 2007 sx210 and feel it pulls me up quite well (strong initial pull then some lag just before ski completly gets on top of water) and has a very managable although wide wake at 15 off. Might be in the market for a new boat and don't need the space of the 21' any more so looking at the 195 but can't sacrifice skiability.
