AR210 Bilge pump Fuse location
JoseCuervo
Hi would someone guide me to find the Bilge pump auto fuse for the AR210 ? Thanks !
There should be circuit breakers next to the switch. Just push to reset.
Check out page 44
Check out page 44
Thank you for the feedback. The CB is working fine. I just found that the auto function of the bilge it’s not working. I check the auto wire to see if it’s getting power from the battery and my voltmeter it’s not showing any power.
If I turn the bilge manually it works fine.
I test it once a month and it failed the test last night. I was wondering if the auto wired has a fuse somewhere.
Did you try the 3 fuses that are located right next to the battery switch under the port-side seat? I believe one may be the auto-bilge that's wired to the line side of the switch.
Yes , I found the auto bilge fuse right in that place. Thank you. It’s a 3amp fuse and was blowed. I replaced it and problem solved. Thank you.
