AR210 weight?
Biohazard
Hello all. Could anyone tell me the weight of the AR210 with trailer? Thank you.
Approx 3300 lbs dry
Thank you I saw that on the site. I wanted to know weight with trailer since they do not list the weight of their trailer.
They used to list the dry weight with trailer on previous models. The trailer is probably around 1200 lbs so it would be around 4500 dry.
Ok thank you Ancient Canoe
If you are cutting close on tow capacity, keep in mind that fully fueled would add another 300lbs, and other gear adds up as well.
