AR230 circa 2008. High pitched sound across rpms on starboard engine.
scotta50
Replaced sleeves last year with nylon. Impeller appears clean and clear. Ideas welcome.
does it have the same sound out of the water?
I might remove the impeller/shaft and run it on the hose to see if the sound is still there to help determine engine vs impeller/shaft
Have you ever removed the cone and checked the impeller bearings?
