h8bogez
- Boatless
- NA
I bought a 2017 AR240 in September last year. I pulled the batteries for the winter and I even took a picture of the wiring before I did. As luck would have it, I got new phone and the picture wasn't pulled from the old phone.
The manual has a 1"x 1" picture of the wiring for the dual batteries, which is hard to tell which negative wires go on which batteries.
I ran the boat this past weekend but I have a couple of questions. I am afraid I wired this incorrectly.
1) Both my house and starter switches need to be turned on for anything to work. If my starter switch is off but house turned on, no electronics work. Does someone have a clearer diagram of the wiring?
2) DVSR lead...I have searched multiple threads. I have seen this wire attached to the house and starter battery. The label says connect to the "common" battery, which is what starter or house?
3) Lastly, I have a ProMariner 12 dual bank charger to install. The plan is to take the boat from storage to my driveway and charge overnight before a trip out. Do I need to mess around with cutting the DVSR red wire? The charger will never be plugged in for more than 48 hours. In the winter the batteries are put into my basement and put on individual battery tenders.
Thanks in advance for any advice you can provide,
Chris
Chris
