Just bought an ar240 2016 and was wondering if you could buy the Bimini top like the 242x or limited s that stayed out all the time? Don't need solar panels
4 small clamps (per flag), 3 feet of bungee cord, three 3-foot lengths of half-inch tube (I used aluminum, but SS would be better), 1 foot of solid rod (od=id of tube), two Bomb Wake flag holders, some small nuts, bolts and washers, about 10 inches of noodle, and your favorite 3x5 banner/flag... it takes about a minute to set up. I've used it in 15 to 20 mph winds and it holds fine. I've slow-cruised (13 mph) with it too, but I wouldn't expect it to hold like a normal bimini top would under tougher conditions. The flag holder brackets stay mounted to the tower. The support rod assemblies are held together as one piece by the bungee cord, but will fold down to 3 feet in length for storage. The support rods will float when dropped in the water (noodle). I have 3 different flags that are interchangeable, based on my mood... Yamaha or Kenny Chesney. The flags have a spring clamp mounted to each corner using bolts, uv resistant glue and washers, and when not being used as a bimini extension, I usually hang them from the side of the bimini to stop direct sunlight from coming in from the side. It's easy to make, easy to install, easy to store, and really cost effective. I use the system every time I anchor.Where can I find out more about the MrMoose bimini extension?
Nice! How are you attaching the side curtain/flag?4 small clamps (per flag), 3 feet of bungee cord, three 3-foot lengths of half-inch tube (I used aluminum, but SS would be better), 1 foot of solid rod (od=id of tube), two Bomb Wake flag holders, some small nuts, bolts and washers, about 10 inches of noodle, and your favorite 3x5 banner/flag... it takes about a minute to set up. I've used it in 15 to 20 mph winds and it holds fine. I've slow-cruised (13 mph) with it too, but I wouldn't expect it to hold like a normal bimini top would under tougher conditions. The flag holder brackets stay mounted to the tower. The support rod assemblies are held together as one piece by the bungee cord, but will fold down to 3 feet in length for storage. The support rods will float when dropped in the water (noodle). I have 3 different flags that are interchangeable, based on my mood... Yamaha or Kenny Chesney. The flags have a spring clamp mounted to each corner using bolts, uv resistant glue and washers, and when not being used as a bimini extension, I usually hang them from the side of the bimini to stop direct sunlight from coming in from the side. It's easy to make, easy to install, easy to store, and really cost effective. I use the system every time I anchor.
I used it quite a bit in Bimini this year since two crew members have skin cancer issues.
@RadioWaves, let me know if you have any questions.
Regardless of where I use them, all of my 3x5 flags have a small spring clamp affixed to each corner (using SS/brass washers, bolt, nut, uv resistant glue so that the flag doesn't rip). When using a flag on the side, on the top edge, I just clamp onto the edge of the Yamaha bimini top. On the bottom edge, I clamp onto the windshield frame, and around the tower tube back onto the flag itself. I have some 6 inch mini bungee cords from Home Depot that I use to hook the bottom clamp to a side cleat if the wind is strong enough to pull the bottom clamp off of the windshield frame. It sounds more complicated than it really is. It takes 15 seconds to set up a side flag. I went with flags because they are cheap, thin, strong, and pack really well. I store each of mine separately in a ziploc bag then put all the ziplocs into a nylon bag that I keep all of my flags in. Takes no space, really light and doesn't get tangled and dirty.Nice! How are you attaching the side curtain/flag?
It makes a huge difference. Although it all depends on the direction of the sun, I find the side flags make the biggest difference. Without them, my cockpit seating area is usually 2/3 exposed to direct sun. I expect that the side shade flags would be a good mod for the 2016 boats that have the bigger bimini, but the big bimini would not stop the sun coming in from the sides.Great idea and I am sure it will help. I have had 2 bouts with melanoma so just like your wife i need the shade. Thanks again
Fantastic!Hey everybody,
This is my first post so I hope I don't mess it up haha.
I know this is an old post but I may have a way to help other people with the small Ar240 bimini issue.
I myself was also trying to figure out a way to extend mine because the shade coverage sitting in the driver seat was not the greatest.
So, I decided to try something. I took my bimini canvas off and took it to a local upholstery shop and had them add 18 inches to it. I had them add it a couple inches in front of the hole for the tow point. Then I went to a local metal distributor and bought 3/4 inch stainless steel tubing 1/8 inch thick for the new longer supports. Figured the new longer supports would need to be quite a bit stronger so that's why I chose the thicker SS material. It fit the support holes in the tower perfect. I added a slight bend to them and still kept clearance for my 6'2" height so I wouldn't forget and hit my head. It doesn't fix sun from the side but it's a nice addition when the sun is straight up.
Total cost $250. Cheap fix for the less than adequate top.
View attachment 80486 View attachment 80487 View attachment 80488
