Chadburgess2003
- Stuttgart Arkansas
Have a 2014 ar240ho both engines starts and runs great but all of a sudden the right side engine started stalking when you hit the 6500 rpm range no cough or hesitation just like you turned the key off you can crank it right back up and will run fine till you go over the 6500 range and then it will stall again. Any ideas.
