Maxxam
Hi All,
I am right in the middle of the job but having issues. To begin the fun, the prior owner of my 2020 AR240 siliconed in the entire clean out access panel (to the jet pump shafts). Two hours later I have all the sealant dug out and the panel broken free all the way around. My issue is the tubes connecting the panel to the clean out ports are also sealed on both ends. It is a different color sealant than what the prior owner used (more yellowish and opaque) so I can only assume they were sealed by the factory(?). With the tube clamps completely loosened the tubes will not slide off of either the top or bottom. I recall watching a few videos and others have just unbolted the access panel, loosened the tube clamps and then lifted out the panel. HELP!!
