Audio stopped, everything seems to work but no sound
Navalaviator08
252SE
Hi, I need some help with my stock wet sound audio system on my 2021 252 SE. Out for the first run of the season and the audio stopped working. All the controls work and the display shows all the correct functionality but nothing is coming out of the speakers on any mode - FM, BT etc. The amp is getting power and I reseated all the harnesses. Additionally, I disconnected the swim deck control panel in case the was the source of the problem but no joy. I’m at a loss, please help. Thanks in advance.
If you have the Fusion, make sure you're not muting or powered off from the transom head unit.
It ended up being a failed amp. Wet sounds sent me a replacement because it was still under warranty…barely.
Thanks for your input!
Same issue here on my ’23 AR250 and stock audio. Super annoying on a relatively new boat.
I don’t even know where to start looking :-(
