JeffVans
- Zion Crossroads, Va
- 242 Limited S E-Series
Yeah I thought that’s what mine was supposed to do, but that’s apparently not the case.If you leave the house battery on the bilge will cycle every 2-4 minutes to "sense" water and pump out any if there is any. At least that is how the '17 work maybe someone can confirm that on the '16 boats. Having said that, I think the "cycle to sense" type of pump setup is stupid as well. Sounds like the '18's went to a float type pump and it is live all the time.
In my '17 AR190, I have to have the helm switch clicked to the "on" posistion for the pump to self cycle and be "automatic".Yeah I thought that’s what mine was supposed to do, but that’s apparently not the case.
Yeah I thought I had a pic of it with the bilge pump completely submerged it was about 3 inches over it. I guess the bilge won’t cycle if the Connext screen isn’t on. When we’re chilling at the lake it’ll cycle when we’re listening to music or whatever. This was overnight at the marina.Were you plugs in or out? That really isn't even enough water to be concerned about and it didn't make its way to the bilge area. So how can it pump it out if it isn't there? Or was it so full that it was up to that level?
Not sure how your boat is, but it should be like mine, if my house battery is on then my bilge is on, unless I select to turn it off. I hear it cycle all the time.
Apparently mine doesn’t. I left it on and still came back to enough water that the pump ran for about 3-4 min when I manually turned it on. What was weird though is that when I turned the screen on I think I heard it cycle in/off for a split second but that was it. When screen came on, it was still in auto mode but when I turned the bilge on that’s when it ran the water out.It'll cycle with Connext off, you just need to have your house battery on.
Unfortunately no, it’ll run with the start battery off.Something is wrong with your set up. The way the boat is wired from the factory utilizes the house battery to run the bilge pump. I doesn't matter the key position and it doesn't matter if the Connext screen is on or off. Do you think your pump (for some strange reason) could be wired to they System battery?
I wonder if your pump is going bad.Apparently mine doesn’t. I left it on and still came back to enough water that the pump ran for about 3-4 min when I manually turned it on. What was weird though is that when I turned the screen on I think I heard it cycle in/off for a split second but that was it. When screen came on, it was still in auto mode but when I turned the bilge on that’s when it ran the water out.
Hmmm... mine must be messed up then.This is from the manual 2016 24's with connext:
"Auto Bilge" button
Tap this button or push the joystick knob to select this button to tum on the automatic bilge mode.
When the automatic bilge mode is turned on, a blue bilge-draining symbol and "AUTO" will appear on the boat Icon shown on the display.
The boat checks for accumulated bilge water every 2 minutes and the bilge pump operates to discharge the water.
TIP:
If the bilge pump operates white the main switches are turned to the off position and the battery switches are turned to the ON (green)
position, the interior lights will come on briefly every 2 minutes.
I have also confirmed this to be true on my boat.
