Mohamed Z Sherif
- Long Island NY
- X
wth does it do?
i gotta try it. i can select aux from the screen so why have an on off switch for it? doesn't make sense. i remember plugin my iphone and charging but didn't play music thru it. used bluetooth.If it is this then yes it looks like it tuns AUX on and off.
Being a spare is what I was thinking too do to it’s location. It might be in the owners manual.Are any wires attached to the back side of it? They may be color coded that you can compare to the manual...or the switch itself may just me a spare for anything you want to add ?
Was trying to see if someone already knew about It. Couldn’t find a purpose in the Manuel. I’ll have to plug stuff in and test.Being a spare is what I was thinking too do to it’s location. It might be in the owners manual.
Definitely not cd playerI’ve tried figuring this one out as well. I can hear the relay activating in the back port battery compartment but I cannot figure out what it’s connected too. The aux wire harness under the console has a ground but doesn’t get 12 volts no matter what. So I’m stumped as well. The dealer said it’s for like an external CD player, but I have my doubts that’s true.
I had plans to power my Lowrance fishfinder but that quickly faded..
Did you see if it turns the rear port storage 12v outlet on and off?
can we get a photo when you get a chance?I don't have a photo at this time, but there is a capped plug behind the helm labeled Aux. I added a powered sub to augment the bass in my '18, tying it into that feed. One push of the switch and the amp turns on. Not sure what the circuit is rated for, but the current draw on the powered sub is low and I I've not had any issues to date. I would assume it was added for user-installed accessories. Would be good to know what the capacity of the circuit is for future additions, but I've yet to uncover documentation or trace it back to a fuse.
