Acard7
Jetboaters Commander
- SW Iowa
- 252SE
The other day we took the boat out between rain showers; we were desperate to get it out since it had been two weeks of, I swear, rain every day. When I fired up off the trailer the starboard engine threw an engine flashing code of 13. Thank god for the forum because I quickly looked it up and was the ignition coil code. I checked all the connections to the coils and that the coils were secured. Now the boat ran fine, didn‘t feel like it was misfiring at all and synced with the port engine just fine when I did a small lap near the ramp/dock. Checked the pissers on the side when I was cruising along and they seemed to push out at the same rate. I’ve dealt with misfires due to bad ignition coils in vehicles and they obviously run like absolute sh*t, so felt pretty safe to do a lap around the lake since the boat seemed to be running fine.
I just changed the plugs and gapped them at .30 for all 8. Boat ran fine before I changed them for our water test with the marina and didn’t have the engine code. Watched a video on the YDS software and how to run it but it was obviously on a boat that didn’t have any issues. So my dumb question is, will the YDS tell me which ignition coil had the fault? And if it doesn’t should I just delete the code and then run it to see if it throws the code again? I saw you could test cylinders with a spark gap tester hooked on but didn’t know if anyone had experience with this before I actually go about testing the cylinders. I feel I caused the issue by changing the plugs ? but I was happy all the plugs came out without any issues. As you can see the wife wasn’t too concerned that day.
![A45BFDBA-62CF-4452-8DBD-77F88056CD2A.jpeg A45BFDBA-62CF-4452-8DBD-77F88056CD2A.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/151/151124-403da3aed4b2c96feed63a380071fa32.jpg?hash=QD2jrtSyyW)
