Tom Kaptur
- SX
I was having issues with port side engine - smoke and fuel coming out of exhaust and hard to start. Took it to the Yamaha dealer and the technician said the problem was due to way too much oil. He said the oil got into the air box and then into the wire harness ( through the connector) and traveled through the complete harness and into the ECU. The ECU is now damaged and in result the injector for the #1 cylinder is wide open - which is causing the poor running conditions. Is this possible? Has anyone else heard of or experienced this?
The marina where I keep my boat ( not yamaha dealer) performed my oil change last May and I am questioning them for the too much oil... and asking them to pay for the $3,400 repair - two new harnesses and ECU. They do not believe the analysis of the yamaha technician and say they never heard of such a thing. Also asked why did it take so long to happen. The Y tech. said it can take that long for the oil to travel through.... and said it happens all the time.
Thank you for the help.
