CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
solved: Post #34
i think i remember reading about someone fixing a re-occurring overheat issue, but can't recall the member ...or if it was even this site. if i remember correctly, the "fix" was flushing out a theorized build-up of crud for an extended period of time - i'm curious about the set-up, time, and if any chemicals were used? this is my first boat, but there seems to be quite a bit of crust built up in various places to me.
for some reason, @Ronnie @OperationROL @sysinu all pop into my head for possibilities, but i couldn't turn them up in my searches.
THE DETAILS:
my port engine has been temp faulting. throughout this season, it seemed to fault more often/earlier/easier. my prior outing was october on my way back to the dock after wakeboarding. i know it's not accurate, but feeling various areas, i could not tell one engine was running hotter than the other. out of frustration, i unplugged the thermo switch on the crankcase to avoid the limp mode and get it back to the trailer. it started up an ran fine in the driveway during the flush. i figured i'd mess with it over the winter.
well, my family is in town, so we took it out yesterday (81*F air temp with 72*F water temp). i kept it around 8ooorpms in hopes of preventing the overheat because that worked at the beginning of the season. this time the temp light came on, but it did not go into limp mode. ??? instead of preventing me from going over 3000rpms, it got very loud/boggy and felt like it was cavitating. i pulled some small grass from the cleanout, but it did not help. unplugging the crankcase thermo switch did not change anything either - i did not try unplugging the thermo switch on the exhaust. we anchored for a while and once it cooled, everything was fine again.
looking around today, i am seeing that the inlet on the port engine's water box is showing more "tarnish" than the box on the properly-running starboard engine. it has a layer of dusty/crusty residue on it - like it is evaporating water off it and leaving the minerals behind. so it may indeed be running hotter. my worry is there may be a gasket issue within the large rubber elbow of the exhaust instead of a build-up issue?
last season i had overheat issues with both engines during extended WOT, but the starboard engine has not had an issue this year. prior to the 2015 season, i had both engines out of the boat. at the time, they both got new exhaust manifolds, oil, plugs, air filters, thermostats, a drive-train alignment, and refurbished OEM impellers with new OEM housings. i was careful not to pinch any cooling lines and there are no leaks (brittle lines and rusty clamps were replaced). both pairs of pee-holes are clear/flowing equally.
i will be purchasing the YDS. i'm also going to install the 22mm Trail Tech Temp Sensors near both thermostats like cybuch has:
i want to rule out any false error codes and be able to see trends of the temps in real-time while noting the circumstances the YDS can't: determining if/what variables (RPM and straight vs slalom) increase the temp and which cool the engines better. i'd also like to know what temp trips the idiot light on the dash.
THE DETAILS:
