nate kennedy
Jetboaters Commander
- Rochester MN
- X
I am in the process up venting the bags on my ballast system and eliminating the stock timer since I have different size bags and more bags than a stock 212x. I am hoping for a little help with the wiring... right now a four wire plug plugs into the timer from the switch. 2 plug wire plugs into the timer for power and another 2 plug going to the pump. I’m hoping someone can help me combing them to eliminate the timer. I attached some pics of the 2 diff kinds of plugs if that helps. My plan next year is to add more pumps so I have one for each bag, but that’s not in the cards now and this will help a ton with my fill times as I won’t have to reset the timer constantly
Thanks
Nate
Thanks
Nate
