Battery charger
Scooter
white lake
Help! I’m looking for location suggestions for noco 2 bank battery charger. My house and starting batteries are in the rear port storage compartment.
Here's where a put mine.
My only complaint is that the cord could have been 6" longer. It was long enough to make it, but barely.
9402094021
Here’s the setup in my 210, same charger you’ve got NOCO 2 bank. Put it in with the batteries, way back in the compartment, and put the cord right above. This lets me plug in while it’s on the trailer without climbing aboard, and I can snake the cord back under the cover if necessary.
Think about a battery doctor auto switch. You only need a single bank charger and you'll never forget to switch the battery switch. It charges the engine battery first, then the aux.
View attachment 94020View attachment 94021
You’ve got more room than I do in my 190. I was worried about putting charger in same compartment as batteries. I appreciate the tip and pics!
Silly question, but do you hook up the battery charger cable to the battery terminals and leave them on and just plug in the charger when needed to charge?
Yes
Very nicely done. Thanks for the pics.
Probably would have been more helpful if I had a FSH... I didn't check what model you were running prior to posting. ?‍♂️
