Battery powered and hard wired LED tow point mount
Yup @jeremy0011 thats the exact mistake I made. Did you fill the larger hole then with a larger sized LED or plug?
Yes I was able to use the 3/4" grommet LED to fill the hole. You can’t tell I almost screwed up but it was close.
Can I get wires at auto parts store?
Yes any auto parts store should have wire that will work. I would recommend a 3 conductor 18 gauge cable. I can put a wiring kit together for you if needed but it will take some time. We are camping and boating until July 7th.
I’m currently working on a few options that will make installing the tow point light much easier.
1. For the guys with the 242’s I’m working on a simple circuit that will allow you to use the existing wires that power the courtesy light’s in the tower already. This circuit will allow you to turn on the tow point light and courtesy lights independently using the existing courtesy light switch. This option should be ready in 2 weeks or less.
2. I’m also working on a battery powered light option that uses the Navi Light 360 as the light. My adaptor will have magnets imbedded like the Navi Lights base. This will mean no wires to run just install the adaptor and apply the light. I should have a working example by the end of next week. You can check out the Navi Light 360 by clicking the link below.
Put me down for the circuit! I was planning on just tapping into those lines, but if you have something better for that I'm all aboard.
Ok I've got it installed and working. I was gonna just run some tidy conduit behind my fish finder but realized the wires are in the way of the boat cover. I gotta Run the wires into the forward part of the tower come out and drill through
Anyone know of a grommet that will work well? There's 4 wires. I was thinking to put them in conduit and run the conduit thru the hull.
Jeremy is THE BOMB !!!!!!!!
Jeremy ......... Put me down as #1 for both of the new mods ........ The Light AND the adapter.
Happy to pay in advance !!!!!!!!!
Mikey Lulejian - Lake Oconee, GA
I would use something like this with 2 grommets on each end
http://www.amazon.com/Techflex-Expa...d_sim_e_3?ie=UTF8&refRID=114BRAJS35ZC62AQBHK9
here is how i installed mine
I have made a circuit board that will allow the 242 owners to install and control one of my light kits without running new wires. This circuit will allow you to control the new anchor light and the courtesy lights independently. By toggling the courtesy light switch you can toggle through all three modes (only anchor light, only courtesy lights, or both anchor light and courtesy lights). This circuit is very small 0.5” x 1” and is installed behind the courtesy lights inside the tower. The price is based on how many boards I have produced. I’m curious if anyone would be interested in this circuit.
This weekend I will have a working demo of the new tow point adaptor with magnets installed to work with the Navi Light 360 light. This will allow you to install a tow point light without drilling the tower. Is anyone interested in this option?
I love that Navisafe Navi 360 light, Jeremy !@
I'll take 1 of your new adapters for SURE, ASAP !
Are you gonna be able to supply the 360 light as well ?
Best Wishes and sincere thanks for all of thse super kewl mods you bring us, Jeremy @!
I can include the Navi 360 light for a additional $85 however it will take up to a week to ship as I can not afford to have lots of inventory on hand.
you should kickstarter this and set the value at like 3K. There are enough Yamaha boat owners out there that would back you. For example, if you set the reward as an electronic kit + your tower pylon adapter and LED light for 140$ investment, you would likely get well over 25 people to invest. That gives you initial capital to work with for inventory and then charge 175$ for the kit afterward.
That said, I have the tower pylon adapter and LED light, I just need the light kit circuit board that you have created. I don't want to run new wires, I was actually planning on just tapping into the LED lines that were there for the other lights and using them as my anchor light, but it sounds like your light kit circuit board is much better.
I may be interested in this circuit board.
X2 . This is what I used, I just have the base glued to the tower tow
Point, anytime I need it I just bring it out and pop it into place ( strong magnet). The light has multiple light setting features which is cool too.
Although I'm not an AR driver I like the idea of getting the anchor light higher than the factory mount. Like @steined I was also curious as to what this mod adds to overall height for garage and bridge concerns. Nice work @jeremy0011.
I asked the same question. The answer was it adds 2.2" so 2.5" just to be safe.
I wanted to give you guys an update. I have been successful with modifying my current adaptor to accept the new Navisafe 360 battery powered LED light. This adaptor installs just like my original adaptor but requires no drilling or running wires. It also has the mounting holes if you want to switch to the wired option later. If you haven’t seen the Navisafe 360 it’s a very high quality light, check out the link below. I have a limited number of Navisafe lights and can include one with your order for $85 plus the adaptor $89
Also I have received the first batch of my custom printed 2 sided circuit boards. For those of you with the 242 and don’t want to run new wires, the circuit will allow you to toggle between the courtesy lights and anchor light or both without running new wires. You will just need to install 1 small circuit board behind the 3 courtesy light locations in the tower. They are very small see below. I just need to finish installing the components on the boards but it will need to wait until next week. Have a great weekend I'm off to the lake.
I know I already have an adaptor, but I'd like to order this wireless one as well now that you have it modified. Can you send me a PM with instructions to order another that includes this new wireless LED?
I'm also interested in the adaptor and new wireless LED light. If my math is correct the total price would be $174. Please let me know how to order the adapter and new wieless light?
