Battery powered and hard wired LED tow point mount
Just installed the Navisafe mount on the boat! 400 degrees for about 25 minutes and it slid right on. 10 minutes later it was snug as can be and cool to the touch. A little medium loctite on the machine screw to hold the navisafe base and it is ready to go! Thanks so much for this Jeremy! And thanks to capitalism!
Any adapters for navisafe left. I have the light, just need the adapter. Also, it looks like the adapter only adds an inch or two with the light off. Is that about right? Matt
I have 6 adapters left. When they are gone I will need several commited buyers to justify making another batch.
The adapter itself adds 1/2 a inch and the Navisafe base adds another 1/4 inch. The total height of the adapter and mounted Navisafe LED is 2.3 inches.
After fumbling around with my factory folding light this weekend I decided that I would like a Navisafe light on the tower. Do you have a list of what years your adapter will fit? My boat is a 2007 AR230.
Thank you!
Thank you!
My adapter will not fit your tow point. However another member @aaronkneeland has an adapter for your tow point. Check with Aaron he should be able to take care of you. The center bolt will need to be tapped to accept the Navisafe base screw.
Great, thank you.
Jeremy, pm me you paypal info. need one for my 2014 242 limited S
adaptor and wireless
I paid for my Towpoint light from Jeremy on Thursday and it showed up Monday. What a guy!
He's excellent to deal with. He was very prompt in replying to my questions and I couldnt have asked for better service.
Have confidence in buying from him. Thanks Jeremy!
Jeremy and his "Products" are THE BOMB !!!!!!!!!!!
You'll love the results you get for a tiny bit of mounting effort involved.
We are Blessed to have him here. I enjoyed his stuff on my boat.
Bought one earlier this season. I got the wireless kit and it is terrific! Very cool product......
Jeremy...after trying to use the POS that came with my 192 over the weekend I interested in getting an adapter if you have any left. I don't need a light, just the adapter...if that is possible. Thanks!
Jeremy got me a tow point light mount to me in 2 days. 30 minutes in the oven, 10 minutes to cool, screwed the Navisafe base on and attached the light. This is one of the coolest mods I've done yet. Goodbye OEM junk, hello high end look for $150 and 45 minutes.
So jealous of this. Have an aftermarket older version of the Aerial Airborn on my SX. This means I have a half (ish) rounded sphere with a huge hex bolt down the middle. No easy way to get a wire down because of the hex bolt. So looking for any battery operated option.
Something that attaches to the hex bolt?
I've seen where folks have made a mod where you create a PVC sleeve that slides over the tow point with a battery operated light on top. Can't seem to find a appealing one - or manufactured.
Any help appreciated.
After writing this a lightbulb went off. If I took out the hex bolt and replaced it with a cylinder with a flat top that was the same height / diameter and center hole for the hex bolt .. With the 2 screw points I could then use the many after market lights.
Anyone out there want to machine me something like this? :). Could be on to something.
Buy a slightly longer hex bolt and use it to secure the light?
Oh man... I have to get mine mounted already....
Trying to find something like this which would also work. The image is from a Titan sight no longer functional.
You can always drill and tap the bolt to attach the Navisafe LED. I have done this for a few buddy's and it has worked well.
I'm interested in getting this set up for my 2014 242 limited s. Do you still have boards?
Please send info to my pm. Would like board and wireless set up
