Pbirbeck
- Sherwood, OR
- Limited S
I understand that when underway you have both the House Switch and Start Switch in the on position and the Emergency parallel switch in the off position. When I have the switches in this position the boat only stays in Float Mode even when underway. On the other hand, when I turn on all three switches and the boat is underway the display reads correctly and Float Mode only kicks in when the engines are stopped. Any ideas what may be going on?
