Wrecked Rooster
- Ada, Oklahoma
Okay, I have the holes cut for the speakers. Speaker cables ran to the battery compartment. Ready to do the second battery switch setup and find a place for the amp. On the battery setup, are y’all just gluing, or sticking an external panel to the factory one that’s already there? See pics. Also, I’m wanting to isolate just the starter/ignition to the main battery and everything else to the second battery. Not sure how to go about doing this.
Here’s what I am thinking on the amp and I’m down for suggestions. Thinking of installing L brackets into the bottom of the floor (see pics) and adding the white plastic panel in the same pic. Then mount the amp to it. Is drilling down into that “floor” okay? Thoughts on this setup?
Could setup the amp horizontal but wouldn’t be able to access gain, htz, etc where vertical (see pic) would allow for accessing that and more room for a second amp if necessary.
