dansshin
- Brooklyn Park, MN
- X
My boat came with Battery Tender charging. Is this only needed if you put the boat in storage and aren't going to use the battery for several months? Just trying to determine when I should plug this in to the outlet. I've been using the stock radio on my 212x, when kids want to jump in the water and swim on each of our 4 outings. I think I saw that battery reading was 14v from the instrument panel and doesn't seem to have any issues with radio or starting.
Also there is switch near the battery and after each outing I've been turning it off using that switch. Is that necessary?
I noticed some members have dual battery setup. When is that necessary? Everything on the boat looks to be stock so no high voltage amps or anything like that.
Thank you for your input.
