Battery Wiring
Denny
242 Limited S E-Series
Can anybody send me a picture of how your batteries are connected on a 2020 242 SE I’m not sure mine are correct!
Here is mine for 2019 242X-E, should be close if not the same. I started taking the wires off at the end of last season because I wanted to store the batteries indoors, then remembered I should take a pic. Hence the loose wires with a twisty. Note, there are other wires with fuses, those are from the Minn Kota onboard charger. Hope this helps.
